Televison & Video Logo
Posted on Mar 30, 2017
Hello. My name is Jim Gerondakis. We have several Electrograph digital-ready tv models (32" & 42") we are using at the College of Southern MD (La Plata, MD) in our PE Building. COMCAST (our cable provider) recently cut their analog signal off and is now broadcasting an all-digital signal. We are unable to get the Electrograph tv receivers used in the PE building to the menu section to switch to the digital tuner to program and store the new cable tv channels. The model we are using as a test tv is an Elecrograph Model L321VOKA. We have the Owners Manual and remote but the directions are not clear as to how to access the digital tuner section of the tv for programming.
5 Related Answers
Anonymous
  • Posted on Mar 31, 2008
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
dvinnedge
Dale Vinnedge
  • 35 Answers
  • Posted on Nov 29, 2008
SOURCE: Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
sixstrings24
Zak Hanson-Michelson
  • 35 Answers
  • Posted on Jan 08, 2009
SOURCE: Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Anonymous
  • 5 Answers
  • Posted on Feb 04, 2009
SOURCE: turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. [email protected]
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Anonymous
  • 7 Answers
  • Posted on May 07, 2009
SOURCE: Programming a ATSC DTV tuner on a RCA Universal Remote
Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
Cant get my comcast remote to work with my LG 42
Every brand has several different codes for a single brand as different codes were designed for a brand that uses several different codes.
The Comcast remote if working only has about 50 possible codes built into it----it may just NOT have the one you need.
1helpful
Is my REGZA 42" 42HL167
This REGZA 42" 42HL167 has ATSC digital tuner built-in. when you set the TV to scan for channels, you must set the source to AIR, not CABLE. Since the Digital TV signals use the Old UHF band for transmission, your amplifier is made for this band? Try it without th amp first.
Please leave rating if it helps
This TV has been in use for 2 years. None of the cables have been changed or removed. Apparently hit a button on the remote that blanked the picture & sound. I have a gray screen with menu options,...
Hi Jim:
You can find an owners manual on the Philips site.
There's also a quick start guide and a firmware update.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7320A/37&scy=us&slg=en
Try the above link, should take you to the site..or you can
do a google search....
owners manual Philips 42PF7320A/42
you should see this link in the list of links...maybe the top one.
42PF7320A/37 Philips flat HDTV 42PF7320A 42" plasma digital cable ...
May 25, 2007 ... Philips flat HDTV 42PF7320A 42" plasma digital cable ready with Pixel Plus ... Manuals & documentation · Leaflet · User manual · Quick start guide. + More Manuals and Documentation ...
Hope this helped.
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Bought display w/ no remote, and am hoping to use my Logitech Harmony 880. Any idea how to get it working? The logitech software recognizes the DTS4230 model, but the TV does not respond to the remote.
Hi. If you do not have the original remote for the device, you can call Logitech support. They have the ability to copy in commands for you that other customers with the same model TV as you have learned.
Hope that helps :)
Electrograph DTS4225PTD Plasma TV 42"
It's Y upper buffer, also cross matches, with LJ41-02760A which is for Samsung 42 Plasma
1helpful
Electrograph Plasma TV
you could buy an all for one remote control. i bought the kameleon 6 for 1 and its very easy to programme. just put in one of the codes supplied in the book for the brand of tv you have, once youve put in right code there should be no problem setting up the tv. The best place ive seen for the kameleon remotes is ebay, very cheap compared to what i payed. hope this helps
Top Electrograph Systems Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Electrograph Systems Televison and Video Expert? Answer questions, earn points and help others
