At the present moment my dvd player only plays region 4 dvd's but i need to have i play all regions what code do i put in too change region code
1. Press the 'Set-up' button on the remote control
2. Select the 'System Info' mode from the on-screen menu
3. Using the remote control 10-key type in '1101'
4. 'Region code' should appear as an option on the 'System Info' menu. Initially the region code will be set to 4 (depending on your country). Press '0' on your remote control using the 10-keys to set to multi-region.
5. Press 'OK/Enter' on the remote control.
6. Finish by pressing the 'Set-up' button once more.
I had same prob as ramy53. I suspect Sanyo changes the password every so often. I decided to start pressing 0 and 1 keys randomly and was lucky. I must have stumbled on the right combination!
Have the same problem and when I go into System info...the region code does not appear..am I doing something wrong? I was trying instructions as per Jaffa012001
Thanks so much..please help as this is really getting me crazy!
I have the same problem as kymlor and icuron2.
Have tried jaffa012001 solution but to no avail.
It is most frustrating not to be able to play other region dvd's.
ramy53
I have the same problem and would appreciate any help.
I had the same problem.
This worked well thanks heaps...
Reccommended...
I had same problem. I suspect Sanyo changes the password every so often.
I decided to start pressing 0 and 1 keys randomly. I must have stumbled on the right combination because suddenly the Region code options menu appeared! I can only suggest that people try typing in different combinations of 0 and 1. You could be lucky as I was!
