Black horizontal lines are almost always (90+) of the time caused by a bad panel. Do this...unhook the 2 ribbon cables that go from the tcon board to the panel, release the tabs but leave them sitting in the connector, now move the left one around (from back of set), do you see some flashing on the screen?...if so its the timing board if not its the panel.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: RCA HD52W59 Wavy lines
yes, mine is a hd52w66 i paid $180.00 to have this fixed a week ago and it has happened again. my model does not have a convergence option from the menu so i cannot adjust mine.
SOURCE: rca hd52w59 powers off / need small signal board?
Deflection/power supply board cost 196.00 - SSB 253.00 has tuner on it--------- power board has Flyback transfomer, Check this board capacitor cp150 2200uf 16 v if it is bad you have 2 more caps in same circuit that need to be replaced also 220uf 35v ,there is 3 caps all together cp150--,cp111 or114-- cp120 call UED for parts 1-800-648-6657
SOURCE: RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
SOURCE: I HAVE AN RCA HD52W59 AND THE SET WILL SHUT DOWN
replacing your main board should correct this problem.
SOURCE: rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
