Your charging system isn't working, if you replaced the battery and it worked for a few days, then its not being re charged after starting, I'm assuming you cleaned and tightened all the battery post connections when you installed the new battery , if not do so ,, charge the battery from an outside source, once you know its fully charged,, use a meter, and start the car ,, check the voltages at the battery posts,, you should be getting a reading of 13.5-14.5 volts, if not your alternator isn't charging the battery
