Hotpoint Aquarius WF000 Front Load Washer Logo
Andy Bowskill Posted on Sep 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpiont wf740 all led on the front of the display
Hotpiont wf740 all led on the front of the display flashing ?
  • Andy Bowskill
    Andy Bowskill Sep 07, 2011
    JUST DOING THE BUSHES AS WERE A BIT WORN THANKS ALL THE SME PAL? ANDY B
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Sep 07, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1025560
Points
20216
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
2answers
My washing machine won't spin when in a wash cycle but will spin on a spin cycle
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
1helpful
3answers
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
My wf740 is flashing H20 whats the problem
The code means a water inlet problem.
Check the inlet hose/s for restriction or low pressure..
Check the filter in the end of the inlet valve as well.
There has also been cases of the water freezing in the pipes.
Hope this helps.
5helpful
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
4helpful
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
2helpful
2answers
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
12helpful
3answers
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
HOTPIONT AQUARIUS WF320
interlock may be stuck try changing that
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
