We recently purchased a brand new DC1100XTPS dishwasher and did self installation. The dishwasher seems to work fine and we are very happy with wash quality for the dishes, particularly Sani-Rinse feature.
However dishwasher is leaking from the front door. I have already checked the level, door seal, door latch and everything seems to be fine.
I couldn't figure out what is wrong. The hoses and pump under the dishwasher are just fine. There's something wrong with the door which is causing this leak.
Could this be a loose Door Latch ?
How do I adjust door latch on this model ?
Thanks,
-Irfan Qayyum
[email protected]
i have a whirlpool dishwasher du1055xtsq and the front panel is leaking...do you know what it could be
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
are there soap suds coming out of the door?
Check the float
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
mine is an older model # DU840CWDBO, but i'm having the same problem. of course, i don't have the option of a free warranty service call!
I had the same problem and solved it. Check your installation screws where you anchored the dishwasher into the underside of the countertop. In my case, I had installed the unit slightly backward to much, resulting in the door not closing tight enough against the unit main frame. Good luck!
