Intel Smart Response Technology (SRT) is used for SSD caching to improve system performance. To use it successfully, here are some steps to consider: 1. SSD Compatibility: Ensure that your SSD is compatible with SRT. It should be a SATA SSD. 2. BIOS Settings: In the BIOS, set the SATA mode to RAID (not AHCI or IDE) before configuring SRT. Make sure your motherboard supports SRT as well. 3. Driver Installation: Before enabling SRT, install the latest RAID drivers provided by your motherboard manufacturer. 4. Backup: Backup your important data because enabling SRT involves data migration. 5. Enable SRT: In the BIOS, set the SRT mode to "Enhanced" or "Maximum" depending on your preference. 6. Initialize SSD: Initialize and format the SSD through Windows Disk Management. 7. Install Intel RST: Download and install the latest Intel Rapid Storage Technology (RST) driver and software for your chipset. 8. Enable SRT in RST: Open the Intel RST software and enable SRT. You should see an option to accelerate your HDD with your SSD. 9. Reboot: After configuring SRT, reboot your system. 10. Verify: Check if SRT is working by opening the Intel RST software. It should show your SSD as a cache for your HDD.
If you're encountering crashes or issues, it's essential to ensure compatibility and follow these steps carefully. If the problem persists, consider seeking assistance from your motherboard manufacturer's support or Intel's support, as it could be related to specific hardware or software conflicts.
You would need to ensure that the IR 5020 has a valid IP address (Should be located on the Network Configuration Menu from the on-screen display). When plugged into the network for the first time the printer is usually given an IP address, this would allow you to connect to the web management interface and make changes to the settings from an easier interface than the on-screen display.
If you are planning on sharing the IR 5020 out from the server to other computers then you would then need to assign a static IP address to the IR 5020 so that the IP address would not change once configured.
(Side-note - I do not recommend using DHCP on printers as it can cause issues down the road if the printer is given a defferent IP address by the DHCP server.)
It seems that subtitle file must have exactly same name as movie file.
For example:
Movie file: Mission impossible.avi
Subtitle file: Mission impossible.srt or Mission impossible.sub
or
Movie file: Mission_impossible.avi
Subtitle file: Mission_impossible.srt
Not an easy 123 answer. Setting up scanning depends on the type network you have and the way its configured.. If this is for a business i recommend calling in IT on this one.
make sure the call rerouting always is setup and points to the vm huntgroup, then check the call rerouting assignment points the answer point extn number to the relevant always alternative in night1 and night2 mode
ie; always alternative 10 set all to Reroute and supply vm huntgroup number then program call rerouting assignment for extn during night1 and 2 to 10.
let me know if this resolves the issue if not it could be a number of other timer related / vm configuration / call routing problems which might require a more indepth investigation
