SOURCE: my motorola pebl wont ring
I wrote one of the above problems but found a solution. I took my phone to someone to fix it and she shut the phone off and took the battery out then turned it back on after she replaced it. she then took the battery out while the phone was on and replaced it again and turned it on. she told me it was called power cycling and that it needs to be done every once in a while. it worked perfectly. Hope this works for you too!
SOURCE: Motorla PEBL not ringing
Okay Ive had this phone.
Do any other sounds on there work?
such as music in the sounds area?
Or Sounds in games?
If NOT I would think that the internal speaker has been damged by the water.I would try and get it repaired by motorola,or under warrenty.
If these sounds do work,and it is only just that there is no sound when you get msgs or calls,check your phone is set on a loud style,rather than silent or vibrate.Normally you can change this by going to Settings and icoming call alerts if im remebering right.
Or I Think you you can change it by the side buttons.
Hope Ive Helped You Out.
Good Luck With It.
Sophie x
SOURCE: I can not connect my Motorola U6 PEBL with my PC,
well you need a USB cable and drivers.
get drivers here
Regards
