M-Audio Fast Track USB (FASTTRACK) Audio Input Logo
Posted on Sep 06, 2011
I can record voice, but no guitar. Just as many people on this forum, but i didn't saw a proper answer for my problem. I can hear my guitar im using pro tools SE. The light on my fast track lights up, but there is no signal on my computer. your help would be very appreciated!! In protools Se I selected Guitar instead of voice but that didn't make any difference. I tried audacity. When I put it on mono it only records xlr, but when i put it on stereo it records both inputs but then i have only guitar on the right. So I would like to use Protools SE so if someone has a solution i would be very grateful.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1787
Points
6
In Protools go into hardware setup and make sure that your interface is being read properly. It may be set to something other then your fast track. Then, in the MIX window make sure that your input is set correctly. If your microphone is plugged into input 1, your input on your protools track should correspond to that.
Olympus VN-240 PC
Since you didn't ask a question I can't give you an answer. I can tell you that Olympus' support page for the VN-240PC is here.
I have an Olympus Digital Recorder W-10 with the install disk. I didn't have any problem on my older computers, but I have a new one with Windows Vista Home Premium with 64 bit processor. I loaded the...
The recorder W10 is NOT compatible with Windwos 7, Windows Vista or Windows XP 64 bits
If you have the CD with software "Olympus Voice Album " try install and reconigze tge recorder.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Hello i need to find manuel ge digital message system. to record answer machine of my voice mail how
Since you didn't bother telling us the model of your GE system, you can select it from the list at
http://www.home-electronics.net/ge/pc/user-manuals.asp
I just need the manual for the ICD-B600 Sony IC Recorder. Could you just e-mail me a copy?
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=ICDB600
I can't email it to you since you didn't publish an email address.
Etiennekinai need vn-4100pc driver.where can i download it?
You didn't specify the operating system for which you're seeking the driver. You may or may not see it at
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
2answers
I bought the Philips LFH 9397 dictation system a long time ago, but have only just got round to turning it on for the first time. When I turned it on the words "Philips DPM 9370" flashed on the...
You mean to say you bought a $ 300.00 recorder and didn't take the batteries out during the long time storage?
Hopefully the batteries didn't leak all over the place.
Did you at least try to use new batteries? Two good AAAs can't be very expensive.
2answers
Cannot hear my voice in microphone
These instructions are for Skype 4.2 for Windows or below. Before continuing, we strongly recommend that you upgrade to the latest version. For Skype 5.0 and above, refer to these instructions. If you're not sure which version of Skype you're using, it's easy to find out.
If the person you are talking to in a Skype-to-Skype call cannot hear you there are a number of steps you can take in order to help you set up your system correctly so that others can hear you.
Try calling Echo123. If you can hear your own recorded voice then your playback device (headphones, speakers, etc) and microphone are set up correctly and the problem might stem from low internet bandwidth, or that the person you are calling has not set up their sound devices properly.
If you cannot hear your own voice in Echo123 check that your microphone is on.
Test Echo123 again to see if the microphone now works..
THANKS.
If none of these steps work you might need to adjust your computers sound setup. Have a look at our Sounds Setup Guide.
Also check out our Troubleshooter for more help with common sound setup issues.
Apr 28, 2011 • Skype IM
When making outgoing calls I can hear the person on the other end but they are unble to hear me. I have a Nokia 6120 Classic.
first if your phone have a voice recording option check that your **** is working properly or not by recording any voice for 5 to 7 secs. If it is probable that mic is working properly say you listen the recorded voice than you might have muted the voce increae it by side bottons if present or from phone's sound settings
Jan 12, 2011 • Cell Phones
Trying To Hear Audio Through Headphones While Recording.
There are a lot of people having the same problem with Vista. Check this link for some ideas. I think there is a new on Microsoft update that addresses this issue under audio drivers that gives you more controls in the playback devices tab. Here is the first link:http://forums.techarena.in/vista-hardware-devices/865259.htm Here is another:http://social.answers.microsoft.com/Forums/en-US/vistamedia/thread/217c4402-6668-4592-bd5e-9234247c788f and finally the one that was easiest to understand:http://www.roemersoftware.com/vista-recording-problem.html My son has the same problem with his Compaq laptop and I am truly glad I stuck with XP. Please let me know how you make out.
No signal from xlr input but ok with guitar input
I have the same problem it either accepts voice xlr or guitar xlr but not both inputs at the same time...what to do I have tried everything
Top M-Audio Televison & Video Experts
ExpressFiX
ExpressFiX
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
