You need to dial your voicemail (most phones have it set as 1 on the speed dial). When you are in the voicemail menu there will be options to select, you should be able to select "change greeting", this may be a category under the "voicemail set-up" option in the main menu. When you have selected to change your greeting you will be able to either record a message, set your name as the greeting, or have it read your phone number.
Your voicemail may also be switched off completely, this is usually fixed in the phone settings menu on the phone, or from your phone when you call your voicemail.
How to make a voicemail greeting
Turn on voicemail
Please tell me the model of your phone.However,you can do this with the use of your phone profile i.e from the phone click on it the screw down to the profile then click on it screw to setting or turn setting from there you will be able to get to greeting setting or turn from this step you will be able to activate the turn again .
Good luck.
Thanks for using fixya.
Good luck.
Good luck.
Recording Your Announcement
Before using this answering system, you
should record the announcement (up to
one minute long) that callers will hear
when the system answers a call. If you
choose not to record an announcement,
the system answers with a prerecorded
announcement: "Hello. Please leave a
message after the tone."
1 Press and hold annc/skip. The system
beeps. Speak toward the microphone
normally, from about nine inches away.
While you are recording, the Message
Window displays -.
2 To stop recording, release .annc/skip
The system automatically plays back
your announcement.
To review your announcement, press
and release .annc/skip
You can get a copy of your 1717 manual at this web site:
http://www.retrevo.com/samples/AT%26T-page-2-manuals.html
Hope this helps. Good Luck, Barb
