Microwave Ovens Logo
Posted on Sep 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG MS-1943ALT Micowave not working, light, fan and turntable all work, no heat
Anonymous
Level 3:
  • LG Master 6,771 Answers
  • Posted on Sep 06, 2011
Anonymous
LG Master
Level 3:
Answers
6771
Questions
0
Helped
1776936
Points
21413
From the decription that you have provided, the magnetron is highly suspect and is the most expensive part to replace, cheaper to replace the microwave oven in the long run.
Lg micowave model ms-2645dpa turntable stops and then goes some of the time.
sounds like the drivr belt is worn or sliping, is the plate turning freely on the runners if there worn they can cause the plate to drag that can also cause the this problem
Microwave model MV-1510M is not heating, also sounds louder. Everything else is working, fan, lights, turntable etc..
If everything is working normally, except for heating, the likely cause is the magnetron.  Microwaves can be dangerous to work on, as the site below points out.  If you have an ohmmeter, it is possible to check the magnetron, but be certain to follow the precautions outlined at the webpage:
http://www.gallawa.com/microtech/mag_test.html
7helpful
Not heating
If the oven is doing everything else properly (light comes on, fan runs, turntable goes around) but there's no heat, you may have a failed magnetron tube (the microwave source). There's also a relay that controls power to the tube that may not be working correctly, or the control circuit board is bad. It's also possible one of the door switches is not working (so the oven thinks the door isn't closed), although this usually keeps the turntable and fan from running.
Microwave oven service is not for do-it-yourselfers. There are potentially deadly voltages present even with power off, and a chance of microwave leakage if repairs aren't done properly. Let a professional give an estimate to repair it, or just replace it if it's under $100. (When I was servicing these things it wasn't unusual for a repair to cost over half the price of a new one. That's one of the reasons so few shops still work on small appliances.)
2answers
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
1helpful
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Microwave MS-2645DPA... won't heat food. otherwise works, lights on, turntable working, but nothing heats at all.
tell me about it. try not to buy ge. the sevice charge was almost 200$. it still doesnt work. it has been over 30 days. so they want me to give them another 79$ just to come out again
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
