Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Posted on Sep 12, 2008
Right Door is making loud popping noise
The right door to my side-by-side refrigerator is making avery loud popping noise when it is opened and closed. sounds like it is in the hinge mechanism. Any ideas for a fix? I tried adding some silicon lubrication but it is still loud. thanks Kenmore side by side refrigerator, model#596.52673200, right side door has noise when opening/closing. Sounds like something wrong with the automatic door closer. Is there anyway to fix it? Thanks in advance
lemoinekm
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 25, 2008
lemoinekm
Contributor
Level 1:
Answers
Questions
0
Helped
1413
Points
11
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
2 Related Answers
Daves Appliance Service LLC.
  • 210 Answers
  • Posted on Nov 05, 2008
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
lemoinekm
1helpful
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
2answers
HI,
Noise can come from these areas:
The inside of the freezer
The outside back of the refrigerator
The bottom of the refrigerator
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Loud popping noise occurs when refrigerator door is opened
of course not! you paid good money for that fridge! can you train everyone to open the door only to 85 degrees?
Loud noise top right rear. sounds like a fan bearing going bad. Stops when doors are open.
when you open the door the fan stops......you diagnosed the problem without us.........have a good day.
2helpful
Right door makes a clicking sound
There is a nylon gasket at the bottom of the door hinge pin that needs replacing.
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
1helpful
2answers
Squeaky Door on GE Arctica Refrigerator PSC23NGMB
Use Vaseline on the cam where the plastic slides across onother surface when opening door.
2answers
5helpful
2answers
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
