Question about Kidkraft Baby Gear
My daughter was given a Kidkraft drop side crib and we are not sure how to assemble. There are two slats that we are not sure where they are suppose to be attached and we can not get the sliding side to attach on the bottom (when we get one side done and are working on the other side, the first side comes undone). Also the other side looks like there should be a metal rod going through it but there is no rod. Also have lots of screws but don't know where they all go. Any advice or manual would be helpful. Thank you.
SOURCE:
SOURCE: cosco crib assembly
have a crib that was given to me so dont have instructions
Cosco Sleigh Crib
Model # 90242
please help!!
Posted on Sep 01, 2008
SOURCE: Baby Crib assembly crib made by Domacindo
try contacting modus furniture. telephone *310-827-3490 or 1-800-827-2129
Posted on Oct 28, 2008
SOURCE: Cosco metal crib assembly instructions
put together a baby bed step by step
Posted on May 17, 2009
CribParts
  • 340 Answers
SOURCE: Morigeau Crib model 750
Hi! You can contact a company called Products America at 800-205-9642 or 800-772-1041. They may not be able to provide you with model specific instructions but if you can provide some gerenal information about your crib they may be able to provide a set of instructions similar enough to get the job done! :)
Posted on Jun 19, 2009
Mr_Alejo
SOURCE: Simmons Crib sold under Little Folks Cannot figure out how to assemble.
I hope the instructions in this document work for you:
http://humm.110mb.com/Downloads_Crib.htm
The guide was written for a 1992 Simmons Little Folks Crib but many of their models are very similar.
Also in the same website are the instructions obtained from customerservice@sjfdec.com
Posted on Jul 19, 2009
I need crib instructio.ns for my alexander designs ltd item # 343-8044
I'm just letting you know.I have this same crib..my daughter's leg got stuck in the slats and we had to break them to get it out .called the manufacturers they are claimming they have no record of a crib made by them with this number please be careful
Nov 09, 2012 | Dorel Baby Gear
Gerry Wood Products Crib 9021 Not On Recall List???
Did you try (800) 582-9359 ? I dont see a full size cribs in the recall as you noted, just the porta-cribs. The metal slat the releases the drop side is called a Kick Rail and it was a common design a long time ago. Remember that dropside cribs are now considered dangerous and illegal to sell, via the CPSC website. If you have decided to continue use of the crib, simply create an "L" bracket under the bottom of the dropside that will prohibit the side from lowering. Also note that the CPSC says any crib over 10 years old is considered unsafe. I have personally spoken with Gerry/Huffy in the last 6 months so you should be able to reach them. Please respond if not and I will follow up. Good luck and be safe.
Aug 27, 2012 | Baby Gear
I bought a kinderkraft crib used and it came with the hardware, but no instruction manual. Can I find assembly instrutions online?
  • I can tell you how to assemble it.
  1. Place an insert nut into the top of the stationary rail.
  2. Place another nut into the bottom of that same rail.
  3. Flip that rail over and put another nut into the top and bottom of it the same as you just did.
  4. Now stick a two bolts into one side of the headboard.
  5. Stand up the headboard and twist them bolds from the headboard into the stationary rail.
  6. Now you want to twist two bolts through the secondary headboard and through the other side of the stationary rail. Make sure not to tighten them bolts up to much yet.
  7. Now put the mattress support inside the crib.
  8. Take four bolts into the top holes that are pre-drilled in the slat on the headboard and then on through to the mattress support.
  9. Do the same now with the other slat support for the headboard.
  10. Now do the same with the two remaining slats for the secondary headboard.
  11. Now tighten all the bolts real well.
  12. Put the crib on it's side.
  13. Now your gonna stick the canisters into the legs. Tap them in with a hammer if they are a bit stubborn.
  14. Now slide the rubber off of the lower side bracket.
  15. Hold the front drop rail so that the push plate faces away from the crib.
  16. Now slide that front drop rail on the tracks until it is all the way in the crib and then reinstall the rubber stoppers.
  17. Now put the crib on it's casters and go over the crib and give it a once over and make sure everything is secure and tight.
  18. Crib is ready to use now.
Regards, Tony
May 02, 2011 | Toys
I have my daughter's crib and now I want to use it for my grandson (her son). It's in great shape and we have everything but the instruction manual. It was lost somewhere in between 6 moves. It's a...
Please make sure that a soda can will not fit between the slats as that is the current safety guideline for cribs. As to the sides staying up; if you cannot get the hardware to work, you can drill a nail-sized hole through the side and into the head and foot boards and put a pin through. Later you can put a screw with a wing nut to hold it against little clever fingers. Hope this pertains to your particular model. Happy grandparenting:)
Farmerbear
Aug 30, 2010 | Baby Gear
We have a pre-1980 Welsh Port-a-crib, wooden, with legs that adjust from floor heighth to regular crib heighth. Also, one side has a 4-5" rail that drops forward making it easier to work with baby. We...
the hazard has been identified so there is a danger in putting a baby in the crib
if you get a heavy material crib liner sewn up an put it in the cot with the edges properly secured over the sides then that will prevent the baby's head getting between the slats
the only problem there is , it reduces air flow into the baby so the baby may over heat
in reality , it is the babies life that is more important then the sentimentality of the crib so invest in a safe option
Jun 25, 2017 | Baby Trilogy Innovative Corner Crib
I have a drop side child craft crib white and i have to tighten the slats up all the time on it the bolts are stripping out is this product on recall 47167-0444 15171-18-9-91-835 01700-2-91 these were all...
I have the same crib I believe and I'm trying to figure out if it's been recalled. I think they're recalling all drop side cribs so stop using yours as soon as possible. Better safe than sorry. The first number I know is the zip code. I got the last numbers on my crib too. Hopefully I can figure this out soon.
May 15, 2010 | Child Craft Contemporary Dropside Crib...
Bambino Reale 312C crib conversion to double bed
I have the directions- but it is poorly written by the company...
I could scan and email I guess - if you still need them.
Nov 06, 2009 | Storkcraft Baby Ariel Stages (3-in-1 Crib)
Is this crib recalled wm-1633-0
Storkcraft had a recall on some of their cribs.IF it is a Storkcraft you have to call them and give them the model number.
These cribs were made between May 2000 and November 2008.They were sold until Jan.2009.
Even if your's isn't a Storkcraft you should be able to call the manufacturer of your crib and ask them.
Storkcraft,for one,did not post the model numbers that were recalled.
The manufacturing date can be found on the lower right hand corner of the instruction sheet which is glued on the mattress base.
The cribs were sold in various styles and finishes. The manufacture date, model number, crib name, country of origin, and the firm's name, address, and contact information are located on the assembly instruction sheet attached to the mattress support board. The firm's insignia "storkcraft baby" is inscribed on the drop side teething rail of some cribs.For more information, consumers may contact Stork Craft toll-free at 866-361-3321 anytime to order the free replacement kit or log on to the newwindow.gif firms Web site.
These cribs have had recalls as well:
Jenny Lind crib model 6982 with lot numbers 8021, 8024, 8025, 8052, 8053, 8055, 8056, and 8070 and model 6983 with lot numbers 8022, 8023, 8026, 8027, 8031, 8032.
Aspen 3 in 1, Aspen 4 in 1, Nursery-in-a-Box, Crib N Changer Combo, Chelsea and Pooh 4 in 1. The recall also involves the following Simplicity cribs that used the Graco logo: Aspen 3 in 1, Ultra 3 in 1, Ultra 4 in1, Ultra 5 in 1, Whitney and the Trio.
The recalled cribs have one of the following model numbers, which can be found on the envelope attached to the mattress support and on the label attached to the headboard: 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, and 8996.
13 babies in the US alone died as a result of the Simplicity cribs...in Canada most of them were sold in Zellers...but don't try to take it back there.
pinehurst.jpgLaJobi and CPSC announced two recalls for 4,900 cribs.
First, 2,000 Bonavita "Cabana" cribs were recalled for slat failure -- the slats can come loose and/or break. LaJobi had ten reports of slats coming out of the rails and six reports of slats breaking.
Also, 2,900 Babi Italia "Pinehurst" cribs and Bonavita "Hudson" cribs were recalled for drop side failures.
Step 1 Register your baby crib as soon as you bring it home so you will receive product recalls automatically. Usually manufacturers ask you to register to validate warranty information but this will also register you to receive product recalls.
  • Step 2 Check the U.S. Consumer Product Safety Commission website regularly for recall information. This is a dependable resource that many consumers are not aware of.
  • Step 3 Visit your crib manufacturer's website occasionally and type in your crib name or number under their search option.
  • Step 4 Monitor the recall website www.recalls.gov that constantly updates recall information on all consumer products including baby cribs.
  • Step 5 Stay up to date with current news reports and printed media outlets. They are often the first to announce safety recalls and possible product issues.
  • Sep 22, 2009 | Dorel Alexander
    Crib sturdyness
    If it feels as though it wobbles, a likely problem is that the screws have not been fully tightened. They may feel tight, but give them all one good torque turn or two, until you cant anymore, pretty much. It should solve most of the wobble.
    Jun 04, 2007 | Childesigns Shelby Crib
    Baby Gear Logo
    49 people viewed this question
    Top Kidkraft Baby Gear Experts
    Dorel UK
    Dorel UK
    Jennifer Rock
    Jennifer Rock
    Marvin
    Marvin
    Are you a Kidkraft Baby Gear Expert? Answer questions, earn points and help others
