w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Hope it helps.
Use another computer to download the driver and then copy the driver onto an USB memory stick. Then insert this USB memory stick into your computer and install the driver.
Go to the manufactorer's web site's support site and ask for a replacement number. The disk has numbers on it that will help identify the product. It will also help if you still have the sales receipt. Good luck.
Some info on 98se and USB issues. You should not need a usb driver if the usb port in your computer is already functioning properly. The only inconvenience you will have is your drive will work at the slower speed provided by the usb 1.1 standard.
The link below describes step by step installation of your drive in 98se
Unfortunately, the company only supported: OS: Windows 2000 / XP / Vista / Mac OS X v10.3 or higher and Time Machine (OS X v 10.5 Leopard) compatible, for their USB hard drives.
You would need someone to write a driver for you or to connect to a computer with a supported OS.
Check if the disk is NTFS or FAT32 or some other format. Because if it is in raw format you are dead! Also another tip is call the merchant you bought the USB from. Because if you buy things online, sometimes the product is bad quality. Another solution that saves time is to change to another USB.
