The
problem can be determined through the Wash Progress LEDs. The specific
lit LEDs combination indicates an specific error code that tells what
generally the problem is. But the exact
positions of the lit LEDs are necessary in determining the exact code. Refer to the
illustration below and post back the code or the exact positions of the
lit LEDs. You may Google for the error code once you determine it, like "Fisher and Paykel Fault Code 37".
Please accept the solution
should you find it helpful and/or informative. Accepting the solution will not bar you from
posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Fault code 49 is a cold water valve fault.
Check the wire harness connection between the valves particularly the cold water valve and the Motor
Controller Module. Make sure the connector is fully inserted and reseat
it several times to clean off dirt and corrosion build up. The valves are located along with the motor controller module under the console.
Measure the DC voltage across the cold water valve solenoid terminals when it is supposed to work. Replace the vale if voltage is present; otherwise, check the wire harness connecting it with the motor controller module. Consider replacing the motor controller module if there's no problem with the wire harness and yet no voltage is being delivered by the motor controller module to the valve.
code should be 49. lights from left are lit 3, 4 and 8 light. Any ideas on what code 49 is. I tried to google the code but could not find anything specific to my model.
thank you for the advice. I will ask an electrician to check out the suggested solution
