SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
SOURCE: Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
