SOURCE: Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
Unfortunately, Canon is not supporting Win7 for your scanner. There is a Vista driver (and one for XP). If you have Windows 7 Pro or Ultimate, you can run your scanner in the XP mode (that creates virtual PC). To access the scanned documents, you may need to transfer them to an external medium to share between the "two" computers.
I hope this helps.
Testimonial: "Thanks for a very fast answer. I have Win 7 Prof version so i tray to follow your rec."
SOURCE: I need umax Astra 5800 Scanner Driver and Software
i have umax scaner astraslim 600 but no drier so i want this drier pls
SOURCE: CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
SOURCE: I need a driver for my Canon N650u that is
Hi, try this http://www.hamrick.com/. I've been using it since Vista and am now using it on Windows 7 64-bit. Works a treat and there's even a free trial, so you can be 100% sure it works for you before you buy (not cheap but better than a new scanner, especially if, like me, you only use your scanner a few times a year)
