Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
Posted on Sep 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forgot my password to my Free Agent GoFlex 500 GB hard drive. How can I retreive my data?
Brian Sullivan
Level 3:
  • Seagate Master 27,725 Answers
  • Posted on Sep 06, 2011
Brian Sullivan
Seagate Master
Level 3:
Answers
27725
Questions
Helped
5664243
Points
79191
You could try this software it sounds pretty good although I have not used it so I am unable to direct you on how but it reads as though it has a password reset tool as well as windows password cleaner and a blank the password utility on any user that has a valid account on windows system and many other tools you might find helpful http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
only trying to help
Hope this helps you
Is it ok to defragment my 2T goflex portable hard drive?
Yes. Defragmenting simply takes the pieces of empty space on the drive and groups them together. When you delete data from a drive or it is deleted as part of a program's function (such as deleting files only needed during installation) it leaves a blank space, but files are lined up on the drive. So if the files are like so:
2GB File ' 3 GB File ' 5.5 GB Free Space ' 1.5 GB File ' 4 GB Free Space
Then defragmenting would try to rearrange the files like so:
2 GB File ' 3 GB File ' 1.5 GB File ' 9.5 GB Free Space
So, in short, yes, it's okay to defragment your drive.
My extenal Hard disk seagate free agent 500 gb is not detected by my laptop
try all usb inputs. if it still isn't try another computer. It should be found. Make sure it is plugged in just right or wiggle to see if it finds it. if not then maybe the hard drive is 3.0 usb and the computer is 2.0 just some thoughts
How do i retreive files off my seagate 500 gb freeagent hard drive?
if you can access your drive
click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the destination drive right click select paste or hold the mouse cursor the file/s drag them to your destination drive then drop them in
hope it helps
DID NOT UNPLUG MY EXTERNAL DRIVE CORRECTLY. DO I NEED TO RE-FORMAT THE EXTERNAL DRIVE AND START OVER
no don't do it. as per mi experience, I did not. just change the name of your drive and run chskdsk :/f
HOW TO PARTITION FREE AGENT 500 HARD DISK. i HAVE NO PRIOR EXPERIENCE AND WOULD LIKE TO ENSURE EXISTING DATA IN FREE AGENT REMAINS INTACT. pLEASE ADVISE
First, copy all of the data from the drive to another as a backup.
Now the drive already has a partition or you would not be able to store data on it. Therefore, you could only be speaking about dividing it into multiple partitions.
Therefore you delete the exisiting partition and then create smaller partitions. In Windows you will be limited to 4-partitions.
I hope this helps.
I have purchased a Seagate free agent Goflex 500gb I want to run it with my Mac Pro note book it dose not work
For a MAC to use an external Hard drive, the hard drive has to be formatted FAT32 file system. That is the only file system MAC sees.
1helpful
Multisystem ulility plus supporting OS
If you use the utility that comes with the drive, you will be able to access all of your files and folders that you encrypt on the drive privided that you don't forget your password. If you want to make sure that the drive is protable (can be used on multiple systems), you need to make sure you enable Travel Mode with the Seagate Manager software. You must remember the password in order to access your files.
1helpful
I have a problem with my seagate agent go 500 gb. when plugged in to my laptop it doesn't detect it and it freezes my laptop until i unplug it. how can i get to my files in the external hard drive?
try to connect it to other computer, if it doesn't help, hdd is probably broken. If you disassemble, you will find internal hard drive, which you can try to connect to desktop PC to save your data, or look up for some data recovery company
2helpful
4answers
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
