Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch Logo
Posted on Sep 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought my Iron Man watch a couple of weeks ago and all of a sudden my alarms/timer won't work. The indiglo light flashes but there is no sound or beep. I tried resetting it by pressing all the buttons at once and it did reset it but I still can't hear the beeps or alarms despite turning on when I set the date/time. I don't want to have to buy a new one already or spend the time and money to send in to Timex to either have it fixed or replaced. Can you help me out?
Ansel Alberto
Level 2:
  • Expert 248 Answers
  • Posted on Sep 06, 2011
Ansel Alberto
Expert
Level 2:
Answers
248
Questions
0
Helped
148690
Points
473
Check the caseback of your watch, hold it upright turn it around. look at the markings, if the markings is doesnt match the upright postion you have to open it then put the caseback on its proper position because the part that is beeps is attached on the caseback and the machine has small spring to connect power on it. i hope i had been helped you.
How do I turn up the volume on timex ironman watch alarm?
If the spring is missing, you can wind a temporary one out of extremely fine coil wire around a sewing needle . If watch case is closed and alarm does not sound try stretching the coil slightly. If alarm comes on keep stretching coil a bit further to see if alarm gets louder. Similarly, coil may be too long if alarm does not go on. Then gently squeeze coil a little smaller and put case back together again to check alarm. If it is too soft then squeeze the coil a little more.
There is definitely a sweet spot for coil length whether hand made or store bought. Lots of fiddling but it works.
1helpful
2answers
No instructions came with my Studio Time Watch
I have/had the same problem....just found this pdf file that shows exactly how to do it and it worked!!!!!!!!!! Not sure if you already returned it or not....
Nov 01, 2012 • Watches
1helpful
2answers
Hello , I own a timex iron man triatholon model no t5g691 , the problem is none of the buttons work . they only work when I press them all together to turn it off . I also went recently swimming with it...
this problem occur only if one of the buttons are stuck inside, because you cannot push two or more buttons at the same time unless that you have to reset the watch. 2nd probably the buttons of your watch didnot reached the contact inside, sometimes it needed to be cleaned and had to be lubricated. if still did not work. reset your watch using the reset button inside the watch. i hope this will help you a lot.
1helpful
I got new timex iron man with heart rate monitor. Just after 2months indiglo lights don't function anymore. I need it badly for my early dawn workouts
Do not be so upset - any nearest watchmaker will fix it. All you need is a new battery. Visit your nearest watch repair shop and ask for a new battery to fit in. If you not satisfied: find out in my TIPS here for the manual for your watch. Explanation: When you bought the watch, it was in perfect state (allegedly), everything was working and so on. The thing you do NOT know is: battery was fitted in the workshop long ago, maybe a year or few ago before you bought it. That is OK, co'z watch companies do fit a battery at the point of watch leaving company. So, for example, you bought a brand new watch, but it is not working at all. Wind it up. Or, if you are unable to do the things we do, visit TIMEX download page. Save your nerve and watch as well - send it back and ask for replacement. You will find everything in my tips here on FixYa.
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
88helpful
5answers
Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Jul 25, 2008 • Watches
5helpful
4answers
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
142helpful
10answers
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Dec 04, 2007 • Watches
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
