Cars & Trucks Logo
Posted on Sep 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
  • Elysheva
    Elysheva Apr 02, 2014
    My son's 2002 Elantra kept activating the alarm and then when he went to turn the key in the ignition it wouldn't turn. He does not have a key fob with the alarm on it. We tried the things listed here but nothing worked until this:
PAUL MC G
Level 3:
President:
  • Master 1,280 Answers
  • Posted on Sep 06, 2011
PAUL MC G
Master
Level 3:
President:
Answers
1280
Questions
Helped
702069
Points
2440
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
1helpful
2answers
1helpful
I can't start my 1995 hyundai elantra after forgetting to turn off the lights when going for class. I try to jump start it but the car won't start and all the lights keep on flashing and flick
After connecting battery, try using key in drivers door to lock, and /or unlock. Try passenger if that doesn't work, as well as valet key if it came with one.
2helpful
3answers
My 2004 Hyundai Elantra surges and jumps gears
You got ripped off by the mechanic. A good mechanic can pinpoint the problem by using a scan tool. Take vehicle to autozone or similar and have it scanned for codes this will give you a idea what is wrong. I believe the problem is exhaust related because of the blinking light.
3helpful
2004 hyundai accent flasher problem
this sound like your flasher unit/relay is faulty as both indicators and 4 way hazard lights are not working chech your h/book for location or look under neath the fuse/relay box cover ?there is usually a diagram of location of fuses//relay
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
