To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Gene, mine is the same model.... it isn't flashing a number of times and stopping..but
what it is doing is this.. the light flashes back and forth between the pots and pans and the normal buttons. Then the Heated dry is flashing in time with the other lights. Help Please!!!
also...reset had no effect what so ever... i have checked the heating element and the control board... no effect...Heltp !!
Bevererly, The problem with your dishwasher is the touch pad(it has a key shorted)and the touch pad would need to be replaced by going to apdepot.com and entering in the model # you can find the part # and then order it. Ap depot may or may not be the least expensive place to purchase the touch pad, once ya have the part number, do a google seach using the part number to see who is less expensive.
What does code #1 mean?
Did the reset thing....I was able to try a wash cycle, so I light & the dishwasher started , but the light light went out & the Pots & Pans light came on. I left it wash for a while, then cancelled & drained & the 2 LED lights came back on. I watched for them to blink. They once then paused, then blinked once & paused, etc. I guess that's a code #1.
