Watches Logo
Posted on Sep 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My crystal cracked a couple of months ago and i got it replaced. tonight i noticed that my watch has moisture inside the crystal. what should i do immediately to ensure the watch continues to work. thanks.
Ansel Alberto
Level 2:
  • Expert 248 Answers
  • Posted on Sep 06, 2011
Ansel Alberto
Expert
Level 2:
Answers
248
Questions
0
Helped
148695
Points
473
The crystal is not properly attached it may have tiny opening where moisture goes inside. you have to bring it to watch service center immediately to avoid much bigger problem. i hope i had been helped you.
Watch has film inside the glass. Also, the finish has began to decay in appearance.
The film is from moisture getting into your watch. Moisture can get in one of 3 ways generally. The crystal if cracked, the crown, or the back. In your case since you have buttons for the mulch-functions of the watch you add a possible place for moisture to enter. Take the watch to a watchmaker or watch repair person. Your watch has to be taken out of the case and the case needs to be cleaned. Next the watch tec. may be able to see just where the seals failed and replace them. We of course do this. Also if the gasket is old or out of shape this is a culprit as well.
Hope this helps, gabe
The glass face of this watch has cracked-please advise how to get it replaced and estimated cost--thnak you located eastern massachusetts, usa
Good luck finding a crystal, took me 2 years to find one for my bedat 384 women's watch! Finally took a shot and got one on eBay by luck. I haven't had mine fixed yet but hopefully soon. The crystal alone was 100$ and I have no clue what they will charge me to put in the new crystal. I was given a quote of 200$ over 2 years ago when it first happened.
4helpful
2answers
Water (vapor) under the crystal
Water condensation on the inside of your watch crystal means that moisture has entered your watch, most likely through the hole in which the setting crown/stem is fitted, or, possibly, through the door of your battery compartment. It's usually easier for water to enter a watch then to leave it again. Water inside a watch can quickly corrode delicate parts, causing erratic timekeeping and premature failure of the watch, so you'll want to get it out of your watch as quickly as possible.
Fortunately, it's not that difficult to get moisture out of a Swatch. Pull the crown out into the time setting position and remove the back battery hatch. Then, turn the watch face down and leave it in the sun for a few hours. If you're worried about dust and/or rain getting into your watch, leave it inside a parked car that's in the sun--that will actually speed up the drying process, as car interiors, with the windows closed, quickly heat up far beyond outside ambient temperatures (except in winter). If it's dark outside, you can accelerate the drying process by using a hair dryer set to low / medium heat and heating the crystal gently until the moisture has evaporated. You don't want to heat the crystal too much or else it may start to melt or crack.
Once the water is out of the watch, close up the battery compartment and update the time/date for your watch. You should be good to go, as long as you try to keep your watch dry when doing things like washing hands and the like. If you had been doing so, it's also time to stop wearing your watch when you shower, wash your car, or engage in other activities where the watch is exposed to a lot of water.
1helpful
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
1helpful
Hi. There is water under the crystal on my Sharp watch but, it says on the back that it is waterproof to 100 ft. This watch has been very accurate and, is still, since it was purchased 8 years ago and I...
There may have been some moisture inside the watch when igt was made or as the watch is fairly "old", the seal may have deteriorated.
Many makers recommend servicing (which includes fitting nw seals) ever 3-4 years.
You could try putting it in a warm palce foe a day or so to see if the problem disappears but if it persists, get in touch with the maker with a view to servicing it.
Aug 21, 2010 • Watches
1helpful
Water under crystal
Obviously you have moisture inside the watch. If the crystal is not cracked then moisture can get in around the stem if the seal is no longer good. Although also possible is from a bad seal on the case back. These seals need to be replace every 3 to 4 years and then properly lubricated with a special silicon grease. With time, the seals will tend to flatten out and the grease will dry out. So get it serviced before the moisture will permanently damage it. Also. 330 ft is if you decend slowly. If you jump in a pool or subject it to a heavy spray, like in a shower, that is another story and they don't always keep the water out then.
Dec 12, 2009 • Watches
The crystal is cracked in my Relic mens wristwatch. Can I order a crystal on-line and replace it myself?
Problably not something you should tackle by yourself. I replace them and have experience. You would need to make measurements and order from a place that has inventory. Then you would need to remove case back and movement. Then you would push out the crystal from the inside. The new crystal needs to be installed with the proper "glue". This also needs to be ordered. I suggest you take it to a local watchmaker that knows how to do this. But, best of luck
2helpful
2answers
Submariner water under crystal
You definetely have to ask for watchmakers help to dry out your watch properly. Moisture may not be visible to your eye, but it's still in the watch case and ruins your watch movement permanently and quite quick.
Sooner or later your watch will stop or show some other faults, but by that time the price for repair can be sky-high.
I've been replacing whole movements, just because the owners thought it's not a big deal or didn't want to pay for such a job. It just sounds 'drying out', but actually it's not, as watch must be disassembled completely (incl. movement), cleaned, oiled and properly re-adjusted.
Rolex repairs has never been cheap, but better do it as soon as possible.
Do not forget to rate, please.
Top Ebel Watches Experts
ADMIN Andrew
ADMIN Andrew
Aron
David Kassin
David Kassin
Are you an Ebel Watch Expert? Answer questions, earn points and help others
