Depending on model it have a defrsot timer or perhaps a electronic defrost control but they usually will be located in the control panel if you have a knob used to set the tempature and if it has a digital display that you set the temp. by pushing the button on the front it will have a defrsot control and thats not so easy to put into defrost as the timer is.
Please reply with exact model number as found on the label in the fresh food compartment and i will tell you if you have a defrost timer or electronic control
GENE
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
