@rkbrown1_rb
If your Dell diagnostics shows no fault on the hardware (hdd, memory, chipset, videocard, etc.) but still same issue occurs, I recommend doing another test using a different utility. Try using Hiren's Boot CD that can be found here and try running the S&M Stress Test 1.9.1 and Video Memory Stress Test 1.7.116. If your computer hangs while doing the stress tests, the video card or CPU might be failing already.
Good Luck.
I downloaded the boot disk (dated 8/21/11), but I could not find the exact tools you mentioned. I found and ran "video memory stress test 1.21" and let it run overnight. No errors found. I also ran a couple of other memory tests, with no errors. I am curious if you think this could have something to do with the built in camera. My wife's dell computer is vista and the built in camera blue light flashes about 0.5 seconds after the point where mine locks up. If that is a possibility, how do I disable it at boot up to check?
