What material can I use to make a replacement lint filter for my Avanti D110 dryer? The original is about 9.5" round thin filter material that fits onto the screen lint filter. If I know what material I can use for a DIY
filter I can make my own since this is fragile material and the
Avanti website says it's discontinued.
I am also needing the same. I'd like to think it can be found in a sewing/cloth/material store like Joann Fabrics.
BTW - it's not the screen that needs replacement. This is the somewhat scratchy fabric (just as described) that goes between at the end of what Avanti terms lint and exhaust vent shroud.I am also needing the same. I'd like to think it can be found in a sewing/cloth/material store like Joann Fabrics.
you can order a filter for 11.95 for the round filter in the drum from if you go to www.avantiproducts.com and call the service numer - just tell them your model number and ask for a filter and pay while in conversation. I just did.you can order a filter for 11.95 for the round filter in the drum from if you go to www.avantiproducts.com and call the service numer - just tell them your model number and ask for a filter and pay while in conversation. I just did.
You can't post conmments that contain an email address.
Re: What material can I use to make a replacement lint...
Hi renfrorichte...
I would use fibreglass window screen cut to the size needed.
Bonded with a good glue such as 3M's Weather Proof Adhesive or Contact cement.
Please take time to rate me
you can get the filter by calling their customer service line www.avantiproducts.com I just ordered the big round one for D110 dryer for 11.95you can get the filter by calling their customer service line www.avantiproducts.com I just ordered the big round one for D110 dryer for 11.95
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
If the unit is plugged into a house circuit that has a blown fuse, this unit requires "The fuse (or circuit breaker) size should be 15 amperes". See the manual at... https://duckduckgo.com/l/?kh=-1&uddg=http%3A%2F%2Fwww.avantiproducts.com%2Fmanual%2Fd110.pdf
This allows you to adjust the temperature to match what you are drying. Some fabrics and clothes require low heat or you may only be drying a small amount of clothes and don't need much heat. You also may not want high heat to avoid shrinkage of some clothes.
