ASUS Z91H PUSHED POWER BUTTON BUT WITHOUT DISPLAY
I was using my asus laptop and it suddenly turned off. i was trying to open it again by pushing the power button but nothing happened. there was no display in the screen but the power button still have light. i was trying it with full battery. i even let it stand overnight but nothing changed. please help.
  • fundacionlaf Nov 23, 2008
    My asus has also suddenly turned off several times and when pressing power button nothing happens. I even tried holding it for several minutes or pressing it repeatedly. Sometimes it worked but most times it did not.
  • 67 Answers
Try pressing the power button and press [del] button. See if it goes to the bios setup page. If it does, have your harddisk checked. It could be corrupt OS or problem with your harddisk.
Posted on Sep 15, 2008
SOURCE:
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Eject button stuck
Near the eject button (on the same face as the eject button) there should be a pin hole. Use a straigtened paper clip to force the ejection of a stuck disk. It may also work even without a disk stuck. ( I just tried it on the drive of the laptop.)
Oct 14, 2013 | ASUS Computers & Internet
My asus laptop's power button need to press several times to start...plz help
Mabie power buton is broken or else.... but i need to know what is your asus pc model...
Jul 09, 2012 | ASUS Computers & Internet
I was testing my laptop settings and pushed a turbo button in the in built asus power management software. It warned me about overclocking before restarting my computer. After shutting down, the laptop...
If its still in warranty, try calling the Technical support of your laptop's manufacturer.They will help you over the phone or if possible take a remote access of your computer and resolve the issue for you.
Jun 21, 2017 | Asus UL80Vt A1 Core Duo SU7300 13 GHz 14in...
A white screen display on my laptop
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center or contact ASUS (if in warranty) to have it check for LCD problem.
Mar 16, 2011 | ASUS LCD Monitor
I have a white screen display on my laptop. an asus laptop. tnx
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for LCD issue.
Mar 16, 2011 | ASUS Computers & Internet
I have an asus LCD monitor...with a docking station for my laptop...it was working great one day and the next day...nothing. I've tried ctrl f8 to switch monitors but still says no VGA signal??
laura_vangun, Make sure that ALL the connection points are clean and dust free. also check to see if any gold contacts are bent or broken or have been pushed further into the plastic body of the connectors. (all the connector pins should be same height) If problem persists then try connecting ASUS to KNOWN GOOD desktop pc to see if it still won't display an image of the desktop. Also tell me AGE and or approximate total "on" hours of use this unit has on it. Is it still under warranty? What EXACTLY do you see or hear when you push the "ON/OFF" button to start(power-up) your ASUS unit? Do a comment to your original post and I will try to be of further assistance. 12fixlouie on fixya Bye for now.
Oct 27, 2009 | ASUS LCD Monitor
Blue blank screen is my problem
Problem: An update being pushed out to EEE PC 701SD causing machine not to load to full GUI
Symptom: Machine will start to load into GUI but will get stuck after loading taskbar.
To fix:
Open the Terminal window by pressing Ctl-Alt-T.
Enter the command 'sudo apt-get remove asus-p901-system-update azurebt'
Press power button to turn off machine.
Turn machine back on, open the terminal window again with Ctl-Alt-T.
Enter the command 'sudo apt-get install asus-eeepc-core'
Restart the machine.
May 23, 2009 | ASUS Eee PC 701 Notebook
ASUS X80L has no display
hello..try to remove memory and make a clean using a paper eraser..thanks...^_^ ...
May 13, 2009 | Computers & Internet
My asus laptop cant turn on
you need to replace the Power button...
Apr 12, 2009 | ASUS AC Adapter- Universal Notebook AC...
Computers & Internet Logo
127 people viewed this question
Alun Cox
