SOURCE: I have an american standard
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
SOURCE: My american standard jacuzzi tub is pluged in but
check for power at plug in if power your vacume switch is probably out replace switch.
SOURCE: how to remove jets from american standard jetted
Jet trim usually unthread counter clockwise out of the wall fitting
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
SOURCE: My American Standard spa tub Williamsburg Elite
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
