Question about Xitel INport Deluxe
I have installed and setup the programs as per the manual but when is recording the levels on LP Recorder are not changing but staying the same. Also, once you have stopped recording the file is there but there is no sound which lets me know that it did not actually record correctly. Please help. Thanks Tammy
2 Suggested Answers
SOURCE:
  • 126 Answers
SOURCE: High pitch beep sound over the actual recording
Hmm - it sounds like feedback - when recording it is important to turn off any monitoring or sound out from your computer. To remove the sound you describe from a recording you will need a sound editing software with either an equalizer or a pass-filter so you can filter away the offending tone.
Posted on Jul 14, 2009
I'm having trouble changing the record speed on my dvd/vcr recorder. I would like to change sp to lp or slp. I would like to record 6 hours on a 6 hour tape instead of just recording 2 can anyone help
We perhaps could have been of use, when you had told us in the first place what brand and model your recorder is. For the VCR part, some recorders do have a setting in the menu, to switch to LP (long play) but not all records have this option. So when the manual does not offer this option, your recorder can't.
When you post the details of your recorder, perhaps I manage to find the specs and will be able to tell you what your recorder can and can't. Give me a day, because it is bed time for me.
Feb 01, 2015 | Televison & Video
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
Downloadable drivers for VN4100pc handheld that works on 32 bit
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows 7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
Mar 10, 2010 | Olympus VN-4100PC Digital Voice Recorder
I need Digital Wave Player soft to work with VN-480PC
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
SAVE to the desktop
SAVE to the desktop
Mar 06, 2010 | Olympus VN-4100PC Digital Voice Recorder
I have just changed my laptop with windows 7 but i think i need a driver to update my olympus vn-4100pc is there one
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
SAVE to the desktop
SAVE to the desktop
Feb 21, 2010 | Olympus VN-4100PC Digital Voice Recorder
Still need driver for Olumpus VN-4100pc for xp
1. Open the 'Add / Remove Programs' (Pre-Vista) OR 'Programs and Features' (Vista) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista) OR Programs and Features (Vista).
SAVE to the desktop
SAVE to the desktop
Feb 19, 2010 | Olympus VN-4100PC Digital Voice Recorder
Xitel INport Deluxe Logo
149 people viewed this question
Top Xitel Computers & Internet Experts
Marvin
Marvin
Peter Dragonetti
 Grubhead
Grubhead
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
