iRiver H10 MP3 Player Logo
Posted on Oct 07, 2017
I just bought the E300 iriver mp3 player. It did not come with instructions and when I plug it into my computer it does not recognise a new device in my E: Drive??? I didnt get any software to upload either. I've looked everywhere and there is no upload new music or video option just genre and playlists but not create a new playlist.....confused??
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Apr 22, 2007
SOURCE: Sorting music, rename & creat playlists problams
Provide more info 1/ what windows OS R U Using/2 H10 requires Windows Media Player ver 10 3/ If you do not have XP to run WMP10 then connect H10 in UMS mode, transfer audio files and playlists using windows explorer 4/then use EasyH10 to update the database on H10
Anonymous
  • Posted on Jan 29, 2008
SOURCE: how do I create playlists for iriver H320
I too wanted playlist and found it out for v 1.25 K. I am not 100% sure about playlists for version 1.30E sorry, but you can try.
This is how I make playlists. Plug your iriver into your computer. Make a folder on your iriver, call it whatever you want. I called mine playlists.
Create a textfile in the folder, call it whatever you want and give it the extension the same as winamp gives. I think it is .m3u? Maybe .m3p? Anyway, find that out.
Open the file in notepad and put the path to the song. eg:
\music\rock\linkin park\numb.mp3
Add as many as you want one under the other. And make as many playlists as you want. Then unplug your iriver and let it rebuild. In music mode, you have to not be playing a song, so stop any music, then just press the A-B button and a list of the playlists should appear. Select one and away you go. If the press A-B does not work, try holding it. I can't remember as i havn't used mine for a bit.
Sorry I can't be most specific about your version. Or the extension of the file, I wrote a program myself to do the work for me. Check to see if it works for you, if you want a copy of the program I can send it to you. it is in .Net 2 so you will need the the framework installed.
Maylily
  • Posted on Feb 16, 2008
SOURCE: "Playlist On The Go" on a Philips 4 GB SA6045 mp3 player.
I just figured out how you clear the songs from the "playlist to go". go to playlist to go, then when it shows the songs you have added press the up button and you will see the words "clear playlist to go", press the forward button and it will ask you to clear it or cancel, select clear and it will tell you it's cleared.
Anonymous
  • Posted on Apr 26, 2008
SOURCE: iriver mp3 player
One more solution, if the ones above do not work for you: (1) Open the x20 (internal drive: click) in Windows Explorer, (2) Save all of your music into folders (playlists) create in MyMusic (under MyDocuments), (3) highlight all of the folders you created (use the control key), (4) drag all of the folders onto the x20 into the internal drive of x20, (5) Find and play the folders under 'Browse" on the x20.
You have playlists. You just have to 'Browse' the x20 to find them--not 'Playlists'.
Anonymous
  • Posted on Jul 23, 2008
SOURCE: My iriver e100 keeps freezing.
Hey guys,
I had a similiar problem. Apparently when you download music from limewire etc. and upload the music to your iriver, you can upload viruses also. Limewire is very dodgy for this. I'd say delete those songs that are freezing from your player and computer, they may be infected and causing the freeze.
2helpful
I just bought a iriver E300 which is described as "the new all in one pragmatic player", so far its been nothing but problematic!!! there are no instructions, and i cannot work out how to get my...
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player. For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track. Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Iriver plus 3 not recognising iriver x20 player
try to upload the songs onto it with windows media player 11 i only use iriver plus 3 for videos
when ur in windows media go into sync then it has like a side bar just drag the music into that and down the bottom of the bar it says sync press that
and if that doesnt work u might have to buy a new one
1helpful
Computer doesn't recognise device
Either corrupted windows, or bad motherboard. One thing you can do is unplug power cable and all usb devices, wait about 10 mins... plug everything back in and try it....
External memory - sd card recognition on pc??
if it doesn't even appear on windows explorer either the sd card, usb link or iriver is defective. if all else fails try getting a memory card reader. this allows you to store files on the card through the computer and still be able to insert the card as external storage on the iriver x20. the only trouble with that is that its hard to get the card in and out of the iriver
Iriver mpe player
see if my computer sees the device
Blocked Iriver X20
Yes, try running a format from your computer to the IRiver with it plugged into the USB port. I have done this with several friends MP3 players and it works great. In other words plug your MP3 player into your computer as you usually do and from windows or dos in your accessories run a regular format of the MTP portable device or whichever drive dos says it is. Then presto you can again load music or whatever your MP3 player take into it again.
Car stero won't recognise device
Only solution is to switch to a different type of car adapter, like a casette adapter. iRiver is too small for car manufacturers/adapter manufacturers to bother with.
2answers
4answers
Iriver plus software closes down when I plug in my iriver E10 to the computer
Using Explorer try copying one song over into the music folder of the device. Then restart Plus so that it searches and finds a song present.
Top iRiver Audio Players & Recorders Experts
SmartAviator
SmartAviator
Mohammad Abumuailek
Mohammad Abumuailek
ExpressFiX
ExpressFiX
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
