I have CANON IR-2800 , with ERROR E0002-0000 .
Which key is : FUNCTION and CLEAR, and ERROR?
I know I have to **** copier/function/fclear/error ok, but i dont know which bottom is each one. thank you
or Canon imageRUNNER 2200, 2800 Reset Fuser Error Code
Want to know how to clear the E000, E001, E002, E003, E007 messages on your Canon imageRUNNER 2200, 2800 series machines. Below is the instructions to for the 2200, 2800 reset fuser error code procedure.
For safety reasons lots of copiers and printers turn off AC power to the fusing unit when temperature errors occur. This allows for a service technician to come in and evaluate the machine before it is turned back on. The fuser heats up to to 350 and 425 decrees. Due to the nature of the high heat is why these parts are shut off. No manufacture wants to be blamed for their machine burning down a company. It sounds scarier than what it is. These machines have multiple safety features to keep this from happening. The reset feature is just one safety feature found in the machine
The E000, E001, E002, E003, E007 are all related to high or low temperature readings and the 7 is due to fixing film rotation issue. Below is the procedure to reset these errors. Occasionally, the fuser will run too hot or cool. Sometimes, this is a freak occurrence like when the power flickers on and off or just a faulty reading. Whatever the case, the first thing a tech usually tries is to reset the error and see what happens.
1. If the machine turns back on and starts making copies then you inspect the fuser for possible problems and wear and tear. If it checks out then you let it go and see if it comes back.
2. If the error comes back right away then you know you have a more serious problem and it's time to find out what needs cleaned or replaced. Service Mode Entry
1. Press the User Mode key. (Looks like a little man head. Some people call it the function or additional function key.)
2. Press 2 and 8 on the keypad at the same time.
3. Press the User Mode key on the control panel.
If done correctly the display will read COPIER FEEDER SORTER FAX BOARD
Press the Copier Icon
Press the Function Icon
Press the Clear Icon
Press the Err Icon
To exit service mode : Press the Reset key twice to end service mode and return to the User screen
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again.
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem : E007 code is occurring for the IR 2200 / 2800 / 3300
Solution : In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041. To clear the error: * 2 8 * COPIER FUNCTION CLEAR ERR OK Turn off and on ( main switch )
November 7, 2002
Problem :
Additional Functions>2 key>8 key>Additional Functions (each key is pressed seperately, unlike regular iR copiers) Go to Copier>Functions>Clear> Err_ or Err_Clr. An E000 is a fuser code.
