Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
Posted on Mar 10, 2017
I have been using a Lexicon Lambda USB mixer on a Windows XP computer for several years. Recently I got a new computer running Windows 7 (64-bit) with a Maximus IV Gene-Z motherboard. I used the install disk to install the drivers, but when I plugged in the USB for the Lambda device, my system kept connecting and disconnecting (with the little connect/disconnect chime each time). I downloaded and installed the Windows 7 drivers from the Lexicon site, and the same situation occurs. When I load the Hardware and Devices window in Windows 7 I keep seeing "Unknown Device" appear and disappear in the window. I've tried this in several USB plugs, all with the same results. I've scoured the forums and found no reference... I'm at the end of my rope! I hope you might have some suggestions on how I can resolve this (I gotta be able to record on this machine for my freelance work). Thank you in advance...
5 Related Answers
A
Anonymous
  • Posted on Nov 29, 2007
SOURCE: lexicon lambda
push the monitor button to go mono instead of stereo.
A
Anonymous
  • Posted on Jan 22, 2008
SOURCE: installing omega lexicon desktop recording studio
Yes it's extremly tempramental, just keep repeating the proces it' will work eventually!
Anonymous
  • Posted on Jan 25, 2008
SOURCE: Device is unrecognised always day per day
I've been struggling with this issue for about a week. My unit was locking up increasingly more often.
Two things I've noticed about my Lexicon interface:
1. Seems to be excessively hot.
2. The unit is not vented.
Yesterday, after reading a comment about the solder possibly being the problem, losing conductivity as the units warms up. I decided to run my Lexicon with the plastic case removed.
Since removing the the case, i have only had one instance where the sound stopped working, which i believe was a problem with Cubase in that instance.
I'm not sure if removing the case to keep the unit cooler is the solution. I may have improved a connection somewhere in the process of opening up the unit.
I can say that I went from getting a "new hardware found" message every two minutes to having virtually no problems since removing the case.
My next step will be to drill about 50 holes in the case to vent it before attempting to use the case again.
Best of luck to ya!!!
A
Anonymous
  • Posted on Apr 11, 2008
SOURCE: My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
A
Anonymous
  • Posted on Jul 26, 2008
SOURCE: lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
No Power to the lambda
Make sure the usb socket is working ,the lamda takes current from your computer.Don't use a usb hub.Make sure you are using xp service pack 2 or higher.Try another usb socket.
1helpful
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
2answers
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Sometimes power comes on and sometimes it does not.
Are you running Vista? Lexicon is working on some firmware and software updates to fix the problem. The only workaround is to unplug and replug your USB cable when it stops working. As long as you are actually using the Lambda, it should work.
2answers
Lambda lexicon sound problems: is vista the cause?
2answers
Cubase software lexicon Lambda and IMAC
Hey robert I can help. What model Imac do you have and Lexicon do you have?? Please let me know.
Top Lexicon Computers & Internet Experts
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
