SOURCE: SATA driver intel DG965OT Mother board windows 2000 server
This board has no win2000 support:
http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm
SOURCE: SATA ports not enabled.
Boot your pc and go into your BIOS. Select ATA/IDE configuration. Select advanced and then drive configuration. Yours should be set to Enhanced ( or Native ). Hit F10 to save and exit or use the top menu. See if this helps. If this did't work you might have a cable that needs a floppy power cable plugged into the hard drive along with others. If this fixed your problem please rate it as fixed. If it didn't just add a comment and I'll be glad to help you further. Thanks.
SOURCE: 250gb sata hard disk to 845 glad mother board
The Power Cable is usually supplied With The computer Cases PSU. newer Power-Supply-Units Usually Have 1 Or 2 SATA Power Cables Attached.
secondly, the motherboard will provide the SATAs Data Connections. ( Usually look Like a Black Plastic ) Letter L shape connector.
Solution. Upgrade Motherboard And Power-Supply-Unit.
Alternative, look on e-bay or similar site, to find a SATA/PCI Card. And A SATA Power Supply Cable.
Mike @ Compurepair.
SOURCE: sata drivers for my mother board
Hello there.
Click here to download drivers for your Intel based motherboard.
You need to choose your version of Windows from the list to continue.
Hope this helps.
SOURCE: add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
