The model number (label) is usually located either on the back of the TV, or on the r/hand side of the TV.
To obtain the best from your set, you ideally want the original factory remote. However, some Samsung remotes share the same functions.
Generally, the remotes are specific to each brand, but some brands of remotes have been known to transmit similar frequencies (i.e. Philips & Samsung).
You can only use a Universal remote, if the remote supports the Samsung programming codes (check the remote's user guide to see if Samsung codes are supported).
Cheers,
