1999 Ducati Monster 600 - Dark - City - Dark city Logo
Posted on Sep 04, 2011
I can not get my Ducati to run it has just been sitting
1helpful
My ducati does not start. it has been sitting idle for some time and battery is not charged, but i tried to jump it and the engine does not even turn. All fuses are good. fuel is good and has new plugs.
Did you try to push start it? Will it run when you push start it? If so You probably just need a fresh battery. Also check the kickstand kill switch it might be stuck from sitting.
Ducati 2000 SS 750 air temp sensor- where does it go?
there is a section within the tubular structure which the clocks sit in where this air sensor with rubber housing sits. Directly infront of the key barrel but behind the oil clock it is a flat piece of metal attached to thesemi circular section.
Top Ducati Experts
Arnie Burke
Arnie Burke
john h
Are you a Ducati Expert? Answer questions, earn points and help others
