Hi kingkumarae,
Due to viruses , the drive cannot be formatted in many cases, however if you want to format it ,
I would recommend that you restart your computer and plug in the pen drive and then do not autorun it.
When you do that , you can right click on the drive that you find in my computer and then rightly click on select format option, and then you can format your drive.
If this does not work in your computer you can possibly try it in your laptop using the same procedure.
Hope this helps ...:)
click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps
