Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
DLP projection TV appear white dot is caused by the aging DMD Chip. To fix it, just replace a new one. Check the DMD Chip replacing guide step by step by perfectbuys
Replace the DLP Chip. You can get it between $145 and Mitsubishi prive of $225. I had the same issue with my 60" DLP. It solved my problem.
