Hi vic_barnes,
You don't need the manual to operate the external hard drive , all you need to do is connect the drive via the USB cable and your computer should accept it , and then you would find a removable drive visible in your my computer option.
Then you can open this drive and copy your files to and from it.
Hope this helps ..:)
I need to copy picture files only but my pc doesn't show any menu when i plug in. how do I selewct this option?
vic.barnes
HI Vic,
When you connect this external hard drive your PC won't show any menu in fact you might get a pop up on your desktop at the bottom left corner indicating that your drive has been connected,
Once you see any error there , that means the drive has not been connected successfully and hence you won't be able to see the drive in my computer , so in this case you can try changing the USB slot where you connect this drive, once you do this the problem should be solved.
Hope this helps ..:) Let me know in case you have any queries.
Thank you for the advice I've managed to get the external hard drive connected and was asked to select which file I wanted to download, I only want to copy my picture file but this does not appear on the list. Any suggestion? Also how do I transfer files to my laptop?
Vic. Barnes
hi Vic,
If you want to select specific files then you need to hold the control key on your keyboard and select the files with with the mouse by clicking on the ones you want, once you have done all the selection you can right click and then select copy , and then go to the location where you want to copy these files and right click again and then select paste and it would be done ...:)
I only want to copy certain files eg Pictures,personal files how do I select them?
