Sir,
I have IR 400 copier machine, i have faced problem of Error massage of E677 when i
give print command from PC. While switching to PC mode it display the massage
WAIT.....
& while making coping this error massage came E677 & also E803 some time.
You are request to please do arrange to give one perfect solution for above error massage.
Waiting for your favorable reply.
Regards
Hitesh - India.
Mob.: (091) 09824402926
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Hitesh, you really don't want a lot do you? :)
I don't think there's a simple answer here, your two error codes are completely different.
E677 refers to an error in communication between the printer & image process board, there would be sub codes 0001 through 0006. Regardless, unless there's a loose wire or connector, the only way to fix this is to replace the boards.
E803 refers to blackened ends on the exposure lamp, possibly caused by a 24 volt power problem. The fix is the same as above.
Hope these help, good luck.... :)
Eerror code e677. just installed new/used board...
fax and printer combo....
The fax works if I take off the connections and the board...
what needs to be connected and does software have to be installed... How do I install software on a copier????
I have clean and service the machine and replace toner but it continuously displays the massage.
E677
E677
we faceing same prblm plz send how to find out tha prblm plzz plzz
