Ovens Logo
Posted on Sep 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Instruction manual rational self cooking centre if possible could you please tell me hoe to get the instruction manual for this manual
Anonymous
Level 3:
Genius:
  • Master 1,239 Answers
  • Posted on Sep 11, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1239
Questions
8
Helped
407047
Points
3279
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Rational CombiMaster Plus System. Good evening, I have a problem with the oven that I have, which is the appearance of E17, and the oven is off. Please help, thank you.
Steam Generator Issue. Call for service, you can't fix these yourself as they are fully computer controlled. Maintaining them is a cost of doing business.
RATIONAL COMBI MASTER PLUS'SERVICE ERROR CODE'S
thehanadvisor.com https://www.thehanadvisor.com > ... > RATIONALCM
Each code will tell you what's wrong with the oven, allowing you to tackle the issue quicker. NOTE: PLEASE SUBSCRIBE E MAIL AND YOU-TUBE CHANNEL. OPEn / H2o.
more here
https://www.google.com/search?q=rational+combimaster+error+code+E17
Manual
https://www.rational-online.com/media/downloads/en-gb/manuals/rational-original-operation-manual-cmp-en-gb.pdf
May 28, 2023 • Ovens
Electrolux oven door won't open
Were you using the dreaded 'Self Cleaning' cycle?
Number one tip, never ever use the self cleaning cycle. The oven locks, wiring and sometimes even the hob wiring can't cope with 1,200'F.
Call for service.
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or 500 C°) to ...
How Self Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Why You should Never Run A Self Clean Oven Cycle & A ...
https://www.generalappliancesvc.com > why-you-shoul...
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) ...
Cpc rational cleanjet didn't start
All question need full 'make model (what it is)', in that order and properly capitalized to help you. The current jumble of words and letter is confusing my search query. However, from my 50 year career in catering I can tell you that if this is a Rational Combi Oven they can only be serviced by factory trained technicians.
When my last one was purchased for $48,000 (Plus $16k to run power, drainage and water [in an airport]) I asked the rep how reliable they were? He told me very reliable and only needs a yearly service. It broke down 6 weeks later. Great machine though and the self cleaning feature is just wonderful.
https://www.google.com/search?q=rational+Cpc+avocado
and worse this way as you wrote it. Even a numerical model number would have helped.
https://www.google.com/search?q=Cpc+avocado+rational
Sep 07, 2022 • Ovens
Rational Combi Steamer. What does error code 39 mean?
Page 105 of the manual.
Cooking cabinet temperature selector switch defective. - Notify customer service!
https://www.rational-online.com/media/downloads/en-us/manuals/80-02-406-bedienungsanleitung-cmp-en-usa.pdf
Jan 15, 2021 • Combi Ovens
Hello evrey one How to solve error 2 in cmp rational oven
First, I'm not a Rational representative.
* This is a Pro oven. Check your warranty. Call your vendor for support.
* Technical support; Tel. 866-891-3528
* Cooking support; Tel; 866-306-2433
* Info; https://www.rational-online.com/portalcontent/club/fs4c/media/files/scc_since_09_2016/brochures/cmp/80.21.517_USA_CombiMaster_Plus_Letter_WA54~1.pdf
* Manual (check page 104);https://www.rational-online.com/portalcontent/club/fs4c/media/files/scc_since_09_2016/handbuecher/manual_cmp/80.02.382_Bedienungsanleitung_CMP_en_uk.pdf
Aloha, ukeboy57
Aug 03, 2018 • Ovens
I have an inglis oven model irp8580. I can't find my manual and I want to know how the self cleaning works.
First of all, here is the main ONLINE SUPPORT page for your model:
http://www.inglis.ca/index.php/en/products/cooking/ranges/ivp8580
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.inglis.ca/images/stories/inglis/pdfs/cooking/inglis_ranges_usecare.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
See page 7 of the ONLINE USER'S MANUAL for complete detailed instructions on how to carry out the self cleaning procedure.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Mar 20, 2011 • Ovens
4helpful
2answers
2answers
GE oven self cleaning
try fix found here http://www.fixya.com/howto/h155060-dreaded_f7_error
worked for me
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
