MSI K8MM-V Motherboard Logo
Posted on Sep 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was using windows xp lately and now i installed windows 7 so now i have a problem with sound. What my be the problem and what is the solution to that problem. please help me. Peter
michael ramos
Level 2:
New Friend:
  • Expert 86 Answers
  • Posted on Sep 03, 2011
michael ramos
Expert
Level 2:
New Friend:
Answers
86
Questions
Helped
59914
Points
176
Hi you need to update the sound driver of your computer go to MSI support website and download the audio driver this is the direct download link of your audio device http://www.msi.com/service/download/driver-2625.html
Anonymous
Level 3:
  • MSI Master 32,281 Answers
Anonymous
MSI Master
Level 3:
Answers
32281
Questions
Helped
7905878
Points
102259
You may be able to download the audio driver from the MSI WEB site.
You can download the device drivers from MSI WEB supportsite, select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
2helpful
IK Multimedia Production IK Multimedia Amplitube 2 Jimi Hendrix Edition Crossgrade/Upgrade (AT200UJHIN) won't play right on windows 7
Have you tried to use XP mode in Windows 7? In Windows 7 you can install XP mode and attempt to run the software from the virtualized environment. For the download for XP mode on Windows 7, go to this website: http://www.microsoft.com/windows/virtual-pc/download.aspx
Another thought that I have is that in Windows 7 - have you searched for an updated signed driver for your sound card? Depending on the model of computer you own - you can usually find the signed drivers at the manufacturers support website. Sometimes, changing the driver you are using for your sound card can also effect how your sound interfaces with different programs.
I hope this bit of information helps!
2helpful
2answers
Sir, i am using windows 7 ultimate. i would like to install another one operating system (i.e) windows xp professional. now i insert the win xp professional disk into it but the install windows xp is...
boot your computer with windows XP cd. it will install winXP automatically but remember to install windows XP other than the drive where your win7 is. for examp: if your win7 is in C drive, install XP in D drive. hope you can do.
2helpful
2answers
I have want to setup Windows xp and windows 7 together .Meaning when start up computer have : Windows xp Windows 7 I try to setup two windows ,but i setup windows xp lost windows 7 and setup windows 7...
Not sure what you have done so far. You need to divide your hard drive into two sections. Install XP first on to one section. Then use a program to manage your computer start up, the one I use is called Easy BCD this is a free program and works great. Once you cut your hard drive and install XP make a copy of your start up partition. Install the Easy BCD program and make a back up again. Then Install Win 7. Then on the Win7 side install the Easy BDC program and set up the menu choices. I run a 3 way boot with XP and Ubuntu. Hope this helps Fix Ya up.
2helpful
5answers
Can i install windows-xp on my laptop which is currently working on windows-7 and use both of them.
Yes you can install windows xp in windows 7.
Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
1helpful
2answers
I have installed windows xp mode in windws 7.but sounds are not working.How can i install xp sound driver to xp mode in windows 7 ultimate?
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
In XP mode itself install the XP driver.
Else you may go to device manager and on the audio driver you may use the update driver option.
Toshiba Satellite L25-S119 Win 7 Audio
Sorry,your sound card driver for windows 7 is not release by tosiba company.Even if they have release driver for Windows Vista too.It might have work.
So you won't be able to play audio sound on your laptop using windows 7.Either you need to downgrade to Windows XP or windows 2000 or you may get a new USB external sound card which support windows 7.
Having no sound after install window
You will need to contact the manufacturer of your sound card to check the availability of a Windows 7 Sound Driver.
It is probably too new for one to be available yet.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question.
10helpful
4answers
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Hi i formatted my comp lately but i dont hav sound now.
remove the sound card from the Device Manager and reboot. Windows XP or higher SHOULD load the best driver for it
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
