Error LED blinking after paper jam, won't print
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
My Printer Epson Photo Stylus 2200 doesn't work any more.
Suddenly all the lights plus the paper button light started to blink.
I have disconnected it(firewire and AC), restarted my computer and
reconnected it, but nothing changed.
Is somebody resolved this problem before?
JF
all lights are blinking including paper feed light. i cannot find any info in the user guide. Does anyone know what the problem is? Epson 2200; Oct 12, 2008; [email protected]; Rich Seeley.
All ink lights and paper light are blinking red!!!
I have the same problem
I did what you said, but mine is still blinking. Also I didn't clean or replace the waste tank, but still, shouldn't it stop?
