It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. Check for tips on the link below to identify parts and removal: http://www.espares.co.uk/advice/washing-machines/a/7
SOURCE: I have a front loading frigidaire washer gallery 1670 series
I would say yes, its worth keeping. Mine leaked a while ago and I bought a new pump assembly. I think it was about $70. You can remove the two screws on the bottom of the bottom face plate and remove the cover. The pump is on the right side. Look for goo leaking out of the shaft seal. Verify before you buy parts, It could be the rubber boot torn or something similar.
Don't reach inside untill its unplugged.
You can replace the shocks easily too. Lots of parts places online with illustrated parts catalogs.
SOURCE: i transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Hello msmm50 - Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines or the water valve.
