Question about Behringer Eurorack Ub802 - Ultra Low-Noise Design 8-Input 2-Bus Mixer
My Behringer mixer Eurorack UB802 doesn't work anymore with condenser microphone like Behringer B-1 ,instead it produces a hissing and pop sound please help me to solve my problems.
    New Friend:
  • 75 Answers
6ya staff
SOURCE:
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
How to use the behringer 802 mixer and connect it to the computer
There are a variety of ways to accomplish this, but the two most common ways are:
  1. Purchase a BEHRINGER USB interface -- like a U-CONTROL UCA222. This will allow you to use the USB port for your sound In/Out. This will also require RCA cables to connect from mixer to UCA222 unit.
  2. Or...purchase a dedicated sound card (preferred) like an M-Audio Audiophile 2496 that can be installed in your computer (not for laptop). You will also need I/O RCA cables to connect.
Dec 26, 2014 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Please can you tell me the difference?
The microphone preamps are different. The Xenyx has lower noise mic preamps.
Nov 04, 2013 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
How to remove white noise in my ub802
It can be a number of things.
Bad ground, excess gain, excess number of mixer channels with no inputs, Make sure the mixer inputs you are going to use are the only ones that are up. Power supply noise- flourescent lighting noise, Clamp on ferrites on the power cords of everything can help reduce this. You can sometimes track the offending source with a battery powered AM/MW radio.
It can also be caused by going from a balanced output to an unbalanced input with some impedance differences.
Feb 07, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Behringer ub802 mixer is buzzing even when no input when i hook my head phones into the headphone jack and main output jack
If it buzzes when you have no inputs AND no output leads connected, there is a problem with the power supply... HOWEVER if you have used UNBALANCED output cables instead of the REQUIRED TRS BALANCED output cables, it is possible the noise is being driven backwards and that is what you are hearing. Note that at full gains, there often is a tiny bit of noise, usually hiss. Also make sure the supply is powered from the SAME receptacle as the equipment this drives such as an amp or powered speakers.
Jul 18, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Can't get cd player to work in my ub802 mixer.what am I doing wrong.I have connected it via RCA cable from cd player to mixer tape in .is this correct.I also have the mixer in tape out and phantom...
Phantom should ONLY be on if using CONDENSER mics or a DI box requiring phantom power... yours should be OFF. cables should be correct. The 2 Trk to mix button should be down.
Jul 04, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack Ub802 - Ultra Low-Noise Design 8-Input 2-Bus Mixer Logo
490 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
