I see you checked everything but still the unit will not run at all.
Here is a link where you can as well download the Manual and information on how the wiring and assembly should be.
I check your concern, the only possible causes could be related to power I believe you mentioned that you already check all connections right, I guess it won't hurt to check the + and - Terminals have the correct cable to it, also make sure the both battery Harnesses are from both batteries are are plugged into their mating Harnesses leading to the charger.
And Additional to the above, the Link is where you can download the wiring info just look for dis-assembly and Assembly this will bring you to the page where the wiring information is.
I hope that this will help you with you concern.
Check all possible power related parts on the device that may be lose or not connected, making sure that all are properly seated/connected and in place.
Have a nice day.
I'm sorry but appearantly you don't understand my problem. I know how to put batteries in and I am smart enough to install the charger and make it all function correctly, but after the charger reach full charge and I unplugged it from the wall the LED light on the dash would know longer come on and the directional/speed lever would no longer engage the motor. I have checked the fuses and circuit breaker and they are fine, I have check all of the other parts of the wiring harness and everthing seems to be in correct working order. What I wanted from you was a wiring diagram for the scooter so I could figure out the wiring that goes to the front of the scooter. I already have an owners manual and have read it front to back with no part of it telling me what I need to know.
I'm still waiting for a reply from your so called expert that cannot even write plain english. I either want to know where to get a wiring diagram for my "PRIDE MAXIMA" 4wheel scooter or I want a refund of my money. I'm beginning to think all the info on the web about this company is true that you are nothing but a ripp off company.
