SOURCE: Raymarine Ray 240 usa model
You cannot just reprogram your Raymarine to european standard.
This radio has been built and is licenced for using with USA frequency, in Europe his use will be limited to lower bands with no modification.
To be fully adapted to higher bands, the radio must be taken apart, and you need to bridge a contact on the main board.
The use of the radio after modifacion won't be legal in Europe.
SOURCE: Raymarine "DSM connection lost"
Murray,
Has the DSM and the E120 software been upgraded to the latest software: 4.12 for the DSM and 5.52 for the E120?
Try this first. You can download the software off Raymarine.com and burn each to a separate compact flash card.
I have seen many problems like you are experiencing solved with this simple change.
If this doesn't solve the problem, the DSM will have to go back to Raymarine for repair.
SOURCE: My Raymarine 435 is showing
Hi. Here is a download of the manual http://www.raymarine.com/raymarine/SubmittedFiles/Handbooks/Navigation/81212_1www.pdf
go to page 18 to learn how to correct your issue. J.
SOURCE: I just bought a boat with a Raymarine C80 chart
Your problem is the 4GB card. The Raymarine C-Series have a problem with their compatability tool and larger CF cards. You should use a card no bigger than 256mb.
The card probably worked in the store because the newer models accept larger cards.
Get an older card from ebay etc and copy your 4gb files onto it and try again. There is more info here: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=1042&p_created=1089743435&p_sid=Y9eWB6ek&p_accessibility=0&p_redirect=&p_lva=1042&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjYsMjYmcF9wcm9kcz0zNiwzNTIsNDEmcF9jYXRzPTAmcF9wdj0zLjQxJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1zaXplIGNhcmQ*&p_li=&p_topview=1
Hope that helps you out.
SOURCE: just interested on ''how'' the
Hi!
The ST1000+ does not have an internal GPS. What it does have is an electronic compass underneath the keypad. When you order the Tillerpilot to steer to a bearing, the unit uses the electronic compass to steer using a series of corrections.
Just in case you've misplaced your Owners Manual, you can use this link to download it to your computer: http://www.raymarine.com/productdocumentfinder.aspx
Click on your language preference, then Autopilots from the drop-down menu, tillerpilots and finally ST 1000+. The pdf file for your unit is 81130_6.pdf
Hope this helps and happy boating!
