Samsung LN-S4695D 46 in. LCD HDTV Logo
Robert Foote Posted on Sep 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I currently have a universal remote for the Samsung LN-S4695D TV, but need the original (lost) to be upgraded to HDTV according to the installer. Where can I purchase one? Bob
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Sep 02, 2011
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006357
Points
237762
Hello
You can buy its original remote control from the Authorised Service Center for Samsung at your town. All functions of the TV can't be controlled by any universal remote control. Some functions may even accessed. If you have the original remote control with you now, you can buy it from any electronic sparepart shops at your town. It will have a number, and should be noted when buying a new one. You can also buy it, either from "Ebay" or "Alibaba.com" by e-payment. Just give them the exact model number of your TV. They will have its number and will send to you by courier. OK.
Need to fined/know the name brand remote control or code number for my LCD TV
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Samsung LN-S4695D LCD WON'T TURN ON BUT POWER LIGHT IS ON ?
I would recommend you get a professional diagnosis. There is high voltage present in the set that can harm you. Being that you never messed with a TV, you could possibly cause more damage to your set. These flat panel TV contain sensitive circuitry. What you are describing sound like a fault with either the power supply or main board.
LN-S4695D replacement stand
do you by chance have a pic of your old broken neck? I have a few Samsung pedestals in stock.
I can not connect my lap to to mysamsung 46in lcd tv
Not much to go on here! I'm assuming you're using a VGA cable. Connect it all up then right click desktop. Select properties then the settings tab and select the appropriate output monitor.
Extra port door cover
It is an extra bottom cover if ever the one in your TV is accidentally broken. You can replace it with that part.
2helpful
The TV won't turn on anymore. The blue light is on but nothing happens when I push the button on the TV or the Remote.
Hi. this is a common issue with many lcd sets. the failure can be found within your set. The part in particular will be the PCB main. The is commonly called the Power Control Board. it basically regulates the current that it receives form the inverter board. There is also a IP that incorporates the cooling devices as well like, the fan and heat sinks but, this is not affected at all. this issue you are experiencing is totally isolated within the PCB and, you will have to replace this board in order to restore this set to optimal performance. i have placed a picture of the damaged part that will need to be replaced.
Please rate and god bless:)
Broken Screen
Replacement LCD panel is on Ebay.
3helpful
Playing ps3
go to bd/dvd settings.scroll down to 108024ghz.Change it to "OFF" not "auto" and not "on"this should do it.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
