On our 6250 Generator, the breaker pops continually. This happens when running only lights on our RV, or when using it to run a water pump. It will run just fine and then the sound changes and the breaker pops. Are there replaceable breakers or fuses that we need to replace. This is a 5000W unit.
Re: On our 6250 Generator, the breaker pops continually. ...
You will have more available power (and use a different larger breaker already on your generator) if you use the 220 plug instead of the 115v plugs. Have an electrician make you an breakout box separating the 220v plug into two 115v outlets. Or your can replace the push button breakers with better quality 25 amp. Problem is that the 115v receptacles are probably 15 amp. Other solution is to try a 220v pump instead of 115v (more efficient draws less amps). Good luck
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
Most likely the air conditioner draws more power than the generator can supply. Check the current needed for the air conditioner in amps. It should be on a plate attached to the it. If the generator is a 5000 watt it can supply 5000 divided by the voltage required by the airconditioner. i.e. 240 (=20.8 amps) if you live in the UK or Ireland or 120 (41.6 amps) in most of the rest of the world. If it's a 12 Volt Airconditioner than you divide 5000 by 12 Note this is the absolute maximum that can be drawn and as power generally fluctuates will still probably cause the circuit breaker to trip. You should ideally be drawing no more than three quarters of the current available. If there are other appliances being run off the generator this again reduces the amount of current available.
Even though you don't specify which breaker is popping, I suspect your main breaker is going as you have 3 appliances that can draw a lot of current if they are calling for power all at once. Try running fridge and/or water heater on propane when using AC, to reduce the load. Many parks and trailers are limited to 30 amp service. Those 3 items drawing power at the same time will usually draw more than that. Add use of a microwave, and your really over.
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
a 6250 watt generator isn't as powerful as you might think.
Here is ohms law for Alternating Current. It is different than for Direct Current
AMPS=
WATTS÷(VOLTS x PF)
I=P÷(E x PF)
A=W÷(V x PF)
WATTS=
VOLTS x AMPS x PF
P=E x I x PF
W=V x A x PF
VOLTS=
WATTS÷AMPS
E=P÷I
V=W÷A
VOLT-AMPS=
VOLTS x AMPS
VA=E x I
VA=V x A
HORSEPOWER=
(V x A x EFF x PF)÷746
POWERFACTOR=
INPUT WATTS÷(V x A)
EFFICIENCY=
(746 x HP)÷(V x A x PF)
A couple of questions come to mind.
1. Has this always happen or is this just recent?
If its always happen you might be running the a/c on a breaker not strong enough.
On the a/c unit on the back there should be a metal plate with the Volts, Amps required to run the unit. Make sure the breaker is rated higher then whats required.
If that all checks out you could very well have a malfunctioning breaker. Its a cheap fix to try to replace. If that doesnt work then one can only assume the a/c unit or your generator is malfuntioning.
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
Try this! To excite it. Shut off the generator! Unplug everything,Then use the 12 volt battery to excite it per manual. Make sure the engine is NOT running and the breaker switch is in the on position. Now with the battery 12V removed restart the generator! This should fix it if the problem is that it lost its magnetism.
