Freezer seems to run too much. There is a luver at bottom of freezer that is full of ice, looks like it is not allowing air to flow properly. Freezer seems cold enough. My thinking is defroster is not working porperly. Ice builds up in bottom of freezer.
Try removing the strap holding the drain hose underneath that drains into the pan. Otherwise it acts like a p-trap and holds water that then insulates the upper part of the tube. Condensate water eventually freezes high up in the tube and backs up everything pushing the condensate water into the bottom of the freezer where it freezes into sheets. Leaving the drain hose down keeps air in the tube all the way back up into the freezer area. This seems to keep the condensate water flowing freely into the bottom pan. The air in the open condensate tube does not seem to have an ill affects. Also, you can add some stranded bare copper wire around the heating element just above the drain tube inlet and then push the tail off the copper wire down into the drain tube hole. This helps keep any water in liquid form flowing down the drain pipe.
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
The air in the freezer is circulated by a fan, there are a number of possibilities
1. Is the internal fan running, this may be switched by the door opening, to test push the small switch on the door frame ( if fitted). If the fan is running go to
2. If the fan is running can you feel air coming out of the bottom of the duct inside at the bottom.
3. If there is no air coming out of the duct the duct is possibly blocked with ice, or the cooling coil at the top is iced up.
4. If there is no air flow then the best and quickest option is to empty the freezer, store your goods elsewhere, switch it off, use a wedge to keep the door partly open and leave off for at least 24 hours. You may find a large pool of water on the floor after this and you will also need to dry out the inside of the cabinet.
Icing of this type is caused by
1. Door not being closed properly, door misaligned or faulty door seals.
2. Putting "hot" product (over 2deg C / 34 deg f) into the freezer.
3. Not covering or sealing product being stored in the freezer.
4. Defrost timing not working (ask your service guy) for this and the rest I'm afraid
5. Defrost heater not working
6. Blocked condensate drain
7. Faulty thermostat, keeps on cooling
The doors should be warm. There or heaters in the doors or what they call a yodelers loop in the frame around the doors that keeps condensation from forming. Make sure the fan if blowing on the compressor and the fan inside the freezer is also running. If so be sure there is no ice built up on the bottom inside back panel of the freezer. If so you will have a defrost problem and the coil is full of ice and not allowing the air to flow through it and cool the fridge. If there is ice, the heater behind the panel is most likely bad.
Check door gaskets if sealing properly? Check to verify freezer is level? If all of the above are fine then look at your drain for the condenasation. It's located at the bottom of your back wall underneath the aluminum evaporator that the cold air comes from. (You will need to remove the back panel inside of freezer wall To get to the drain. It's probably plugged and frozen over. Do not use a chisel or knif instead take a cup of hot water and pour it Oder the drain area and let it sit. (Your freezer will not be running for an hour or so so think ahead or work fast). That being said you have to unplug unit first :-) once you remove all ice push a straw or something through drain to verify its draining through. You can also flush more water down it to watch it drain showing you that it's working. Start with this first.
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
it sound like is not defrosting if is upright freezer. open the back wall jerry if that evaporator is full of ice then it has cut off all the air flow and in return that is why is not freezingif you know how to use the voltage meter you might need to check continuity on the heater if it check ok then repl the bimetal part# 4387499 and timer 482493 when repl time follow the wiring schamatics realy carful look for the right clor harness in the instructions and then just let it defrost or use the hair dryer
