Almost any amplifier will work so there is no "best"... Just make sure the amp RMS rating is a bit below the RMS rating of the speaker for safety of the speaker. A QSC GX5 would be a candidate. You would use one side of it for each speaker if you have two, or use only one side for a single speaker. A lot of pro's seem to use these amps. USE BALANCED interconnections either XLR or TRS cables AND for sure power the amp and the mixer from the same receptacle... it often means running an extension cord like the pro's do to avoid ground bounce noise AND damage to the equipment.
