Phone's "Status Light" Not Illuminating or Battery Failing to Charge 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly. 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
you can also check this link/s:
http://www.mycusthelp.net/uniden/_cs/Ans...[FJ&sFilA=Product&Inc=1199&FB=-1&sFilB=Model&FA=-1&sFilC=&FC=-1&=
http://www.mycusthelp.net/uniden/_cs/sup...[SK
http://www.ehow.com/how_7252483_troubles...
http://www.uniden.com.au/resources_main/...
if you would be needing to change batteries:this site will helphttp://www.atbatt.com/cordless-phone-bat...
2. Remove the battery pack by disconnecting.
3. Leave the battery cover off and the battery pack disconnected for at least 3 days.
4. Once completely dry, reconnect the battery pack and the battery cover.
5. Recharge the handsset's battery pack for 20 hours in the base unit before using the phone. IMPORTANT: You must unplug the telephone line while recharging the battery pack
to avoid charge interruption.
I believe there is a way to export your phone book to another handset, but not without reviving your original phone. Unlike a cell phone, there is no memory card to remove and transfer.
Let me know what happens.
Hope this helps.
